+ Reply to Thread
Results 1 to 9 of 9
Thread: Reading Spark Plugs and Jetting (2-Stroke Only)
  1. #1
    I've been getting a few PMs about jetting and how to read a spark plug on a two-stroke engine. Two strokes are a slightly different beast, and are often misunderstood.
    First, when it comes to reading two stroke spark plugs, forget most of the charts you see on line. Those pictures are of four stroke automotive spark plugs!
    Second, always err on the side of rich, rather than lean! Also, read the next paragraph, and let it roll around in your mind while looking at the rest of this..................
    Two strokes receive all of the engine lubrication through the oil mixed with the gas.
    Gas mix ratios are expressed as parts of gas / parts of oil.
    For example 32 / 1 or 32 to 1 means you are mixing 32 parts of gas to 1 part of oil. This provides more oil than a mix of 40 / 1 or 40 to 1.
    Carburetor jets are a precise fixed orifice, they pass a certain amount of fluid. Jetting is the act of changing that set amount of fluid flow.
    This is a hard concept for a lot of folks to grasp, but changing the oil to fuel ratio changes your "jetting" also. The fixed orifice flows the same amount of liquid,
    but changing the make up of that liquid effectively also changes the "jetting"!
    Keep this in mind, it' will come up again later. But, onto and back to spark plugs!
    OK, here goes........................
    These pictures will probably, (almost certainly), be different than what you usually see. Why? Because what is usually shown are four-stroke automotive plugs!
    First, let me show you a few different types of plugs you will probably run into, and a few you may never see.
    The first, is your "garden variety" standard spark plug, that most of you probably have in your bike:
    You may also see the next kind of plug, the fine wire electrode spark plug. Most of these will be made with an "exotic" metal like platinum, gold, copper, etc. and may be referred to as a "racing plug". They are usually priced a little higher, generally fire better under adverse conditions, but really don't make a noticeable difference over the "standard" plug
    The next plug is a multiple ground electrode spark plug. These too are usually a fine wire / exotic metal plug. No real difference over a "standard" plug, but a new twist to improve on firing under adverse conditions.
    The last plug used to be a very popular "racing plug" when CDI ignitions first came out about 25 years ago. If you do much "vintage" bike restoration, this type came stock on the early Yamaha and Suzuki MX bikes. It's a surface gap or retracted gap spark plug.
    Another thing to watch is reach or the length of the threaded shank of the spark plug. Generally there is three different reaches of spark plugs. If you have any doubt over what you need consult your owners manual, shop manual, or worst case, pull the head and look! Time and money wise, you are way ahead doing that than breaking a piston crown, and risking a bent rod! Here's an example of the different lengths.
    OK, lets look at the kinds of things you'll see while getting your jetting sorted out.
    The first picture is of a correctly jetted plug. The center electrode and the bent side ground electrode should be a nice medium to light tan. The outer threaded shell on this plug is just slightly wet, and could use just about a 1/4 turn less air screw, but is looking pretty good over all. If your's looks looks like this, you are 95% there!
    Next, let's look at some unhappy plugs, some that you are quite likely to see. The first plug is from a very rich engine, that also need the air filter cleaned. Not only is it a wet / sooty black, but it shows a lot of fine dirt that has gotten sucked through the filter. The second plug is also too rich, but is a dryer "sootier" black. I's closer to the correct jetting, but still probably at least 2 sizes too big on the main jet, and could probably use the needle dropped one clip.
    The Next plug you may see too, but not for long. Why? Because it's lean, and too lean on a two stroke means too much heat is being generated. Note: this carb is off all over, the outside threaded shell shows it to be too rich on the idle or pilot jet circuit, but lean on the main jet circuit. You can't really fix this by adding oil (remember that paragraph I asked you to read and keep thinking about) because the extra heat will cook off the oil, resulting in the second spark plug picture. The one coated with melted aluminum from the top of your piston. If this piston doesn't seize to the cylinder wall, there will be a hole melted through the top of the piston, and the bike looses all compression.
    Something else to consider; plugs have a heat range, a rating that tells you how much heat transfer or retention the plug is rated at. This will also affect your jetting, and give you one more suttle tool to work with.
    NGK and Champion plugs have an oposite heat range number system.
    NGK Heat Range: Lower number is hotter, higher number is cooler.
    IE: BR8XX is hotter than a BR9XX, and a BR8XX is colder than a BR7XX.
    Champion Heat Range: Higher number is hotter, lower number is colder.
    IE: N2X is hotter than a N1X, and a N2X is colder than a N3X
    Heat Range Crossover:
    NGK-------------Champion
    BR7XX----------N3X
    BR8XX----------N2X
    BR9XX----------N1X
    Common NGK Plug Types:
    BR8ES or BR8EG = Standard Plug
    BR8EIX = Iridium Plug
    BR8ECM = Compact (shorter and easier to change)
    BR8ECMIX = Iridium Compact Plug
    When making jetting changes; first, settle on an oil to gas mix ratio and stick with it! It really doesn't matter whether it's 32, 40, or 50 to 1. Pick a good quality oil you trust, follow the manufacture's mix ratio, then worry about your jetting. Why?
    Adding more oil to your gas makes the mixture leaner (more oil and less gas), subtracting oil from your gas makes the mixture richer.
    For beginnings, let's assume you motor is jetted correctly. Now, lets assume you jetted that bike using a 38 to 1 oil mix. If you change that mix to 32 to 1 you have leaned out the bike (more oil means less gas) if you change to a 40 to 1 mix you have richen up the bike (less oil means more gas).
    When you get your jetting close to that 95% spot, making any radical change can push you over the line from safe and clean to "push it home"..........................
    Let me know what you think about this, and maybe I'll do a jetting "how to" write up next if any one is interested.
    Hey! I only start out slow!
    Then I get slower...............
  2. #2
    Re: Reading Spark Plugs and Jetting (2-Stroke)
    nice writeup.
    reminds me i still need to rejet my GFs kx this weekend.
    but id like to add, that with todays modern fuel, the color of the plug doesnt say much. youll want to be looking a lot closer at the contamination/damage to the electrode as a sign of extreme lean/rich conditions...then look at the bikes performance at different throttle openings under load. revving the bike in your garage will tell you nothing.
  3. #3
    Join Date
    November 15th, 2006
    Location
    South Side
    Posts
    7,750
    vCash
    5000
    Wow!! Nice write up Now I need to go look at my plugs...
    Get Out And Ride!
  4. #4
    Join Date
    June 10th, 2007
    Location
    West Green Valley
    Posts
    1,388
    vCash
    5000
    Nice Terry!!! How about one for four strokes... I just added a pipe and rejetted recently ( my first try at jetting my self) sure would like to see some info on it, Thanks
    JACKRABBITS MC LAS VEGAS -Pres 2009/2010
    MRAN 7c AM 2010
    D37 o444 Desert 2010
    "Only those who will risk going too far can possibly find out how far one can go"
    Jackrabbitsmclv.com -- "A Family of Friends"
  5. #5
    hey jay, what jetting did you use? i should be able to help ya on that one.
    This recommendation requires air box flow mods and an open stock or aftermarket pipe and ACV circuit intact.
    Elevation 0 to 4,000. feet
    30 to 45 degrees: 172 main, JD Blue #5, 48 Pilot, 2.0 turns, 75 starter jet, #0 leak jet
    45 to 60 degrees: 170 main, JD Blue #4, 48 Pilot, 1.75 turns, 72 starter jet, #0 leak jet
    60 to 75 degrees: 168 main, JD Blue #3 or JD Red #5, 48 Pilot, 1.5 turns, 70 starter jet, #40 leak jet
    75 to 90 degrees: 165 main, JD Red #5, 48 Pilot, 1.25 turns, 68 starter jet, #50 leak jet
    90 degrees plus: 160 main, JD Red #4, 45 Pilot, 2.0 turns, 65 starter jet, #60 leak jet
    did you get a JD kit or something?
  6. #6
    Join Date
    June 10th, 2007
    Location
    West Green Valley
    Posts
    1,388
    vCash
    5000
    I got the Yamaha GYTR AIS removal kit, which comes with jets / mains / etc.. That is what I installed . I also have the JD kit just so I have more options for tuning. I have installed a DR. D pipe. SS model , full system. I also have removed the snorkle, added 4 UNI air box 1 inch filters, Cut the grey wire, New YZ throttle stop. And left the other circut / thing a ma jig in tact... I will have to get back to you on what mains / pilots / clip positions , etc I installed. Basically I installed what GYTR recomended reguardless what the JD kit said. I did not want to second guess them by mixing things up. I wanted to try this first as a Base line to start from... I will look at my notes and get back to you. Thanks. By the way it runs GREAT... I think I got the jetting really close. Just needs a little fine tuning...
    MRAN 7c AM 2010
  7. #7
    See, there you guys go, cluttering up the two stroke thread with four stroke jetting.............
    It's like apples and oranges, both fruit, but totally different!
    Balias is taking the easy way out, (and I did too), by going with JD. I used his chart for 4 years, setting up my 525 for out of town races just by "Google Earth'ing" the elevation and following his charts. I ran stuff from sea level to 8500' and never a hiccup..................
  8. #8
    Re: Reading Spark Plugs and Jetting (2-Stroke Only)
    i thought jay had the JD kit.
    but i only use it for 1 of my 3 bikes.....and my race SM bike uses gbalias jetting and happens to be the best performer. hmmmm.
    hahahaha.
    but yea.....no more 4stroke stuff on this thread.
  9. #9
    Join Date
    June 10th, 2007
    Location
    West Green Valley
    Posts
    1,388
    vCash
    5000
    OK... So then back to my orginal Question... Hey Terry... How about one for FOUR STROKES..... Thanks... PS if you need to know what I have done to my bike recently ... Just refer to this thread. Thanks again!
    MRAN 7c AM 2010
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
