Fixing dents on exhaust headers
Lets get Dirty!!
Moderators: Supertrunk, Charlie_Hustle
Postby Tristan899 on Sat Jul 24, 2010 11:52 am
Does anyone know anybody in town that fixes dents on headers? Mine got pretty banged up at the night race and i just bought it so id really like to get it fixed. Thank you!
Tristan899
Lurker
Lurker
Motorcycle: Yamaha Yz250f
Re: Fixing dents on exhaust headers
Postby JohnnyJeep on Sat Jul 24, 2010 2:02 pm
Fill it with water, plug the ends and freeze it. Watch it so it doesn't over expand
John
"Man does not live by pavement alone!"
User avatar
JohnnyJeep
Privateer
Privateer
Postby jim13 on Sat Jul 24, 2010 2:48 pm
I've used this trick with good luck on large dents, but small rock rings are usually still left. If youy don't see good results with the first time, try it several and see what happens.
jim13
Lurker
Lurker
Motorcycle: 2008 YZ450f
Postby grandpa1 on Sat Jul 24, 2010 3:00 pm
You can try this guy, bruce, 379-6112.
grandpa1
Lurker
Lurker
Motorcycle: none
Postby Yodiracer on Sat Jul 24, 2010 3:17 pm
Another way to do it (my preferred way) if you have access to a oxy/acetylene torch is to fab two caps from steel pipe and o-rings and install a shrader air valve in one of the plugs. Hook up to air compessor with about 50 psi and then heat dent until it pops out. It helps to have a buddy with all this stuff but I can give you his phone number if your interested. He charges $30.
Greg Yoder
5c Exp
Wild Bunch M/C
2001 Honda Cr250r
1987 Yamaha Warrior 350
"Courage is being scared to death... and saddling up anyway."
John Wayne
User avatar
Yodiracer
Knee Dragger
Knee Dragger
Motorcycle: 2001 Honda Cr250r
Postby sirhk100 on Mon Jul 26, 2010 7:27 am
JohnnyJeep wrote:Fill it with water, plug the ends and freeze it. Watch it so it doesn't over expand
Before throwing away an old pipe of mine I tried this just for the fun factor. It resulted in it looking pretty much the same with virtually all the dents still there, and a nice 5" crack down a weld seam. This was on a 2T pipe though...
Khris
sirhk100
Tank Slapper
Tank Slapper
Motorcycle: KTM300
Postby BestNThDez on Mon Jul 26, 2010 7:36 am
Johnny, out of curiosity, is it really necessary to plug the ends of the pipe before freezing? It doesn't seem to me that it'd make a difference, since it's the ice that forms that will push the dent out. Unless of course it's to keep the water from spilling out before freezing. I've never tried this technique, but heard it works well for larger dents and that sometimes several freezes are necessary.
User avatar
BestNThDez
Rookie
Rookie
Motorcycle: KTM
Postby sirhk100 on Mon Jul 26, 2010 9:53 am
When I tried it on that old pipe, I plugged the engine side, filled it up with water and stood it up so the silencer end was at top. Didn't plug that end. It definitely expanded like we've all be told, unfortunately the weld seam on the FMF fatty was weaker then popping dents out and ended up being the victim. No biggie though, the pipe was slated for trash like I said, it was just an experiment more then anything....
sirhk100
Tank Slapper
Tank Slapper
Motorcycle: KTM300
Postby LVThumper on Mon Jul 26, 2010 10:42 am
You can use the the rubber end stops and hose clamps from Home Depot. They work great to hold the water in while it's freezing. I have done it a couple times and it definitely gets the big dents out. The little ones require the heated gas method. :thumbup
I don't have OCD, I have CDO. . . It's like OCD except the letters are in alphabetical order.
Gamblers M/C
User avatar
LVThumper
Knee Dragger
Knee Dragger
Motorcycle: 08 YZ450 - 42p
Postby tabula_rasa on Mon Jul 26, 2010 5:18 pm
You can do it all yourself like Yodi described for about $40 in parts (except for the compressor) but Bruce is an exhaust WIZARD. He not only pops the dents but also welds like a pro (cracks, ripped off mounts) and polishes or power coats all for $30.
I have made it my mission to bring him a pipe he can't fix and so far he is winning 8-0. I squished my pipe into pancakes, elephant ears , pretzels, ripped off mounts, all on the same pipe mind you, and it still looks like new.
I am not affiliated with Bruce in any way, I just can't believe that he just won't let me destroy a pipe.
What doesn't kill you....
will make you wish you were dead.....
when you get the hospital bill....
User avatar
tabula_rasa
Rookie
Rookie
Motorcycle: XV1100S, CR250
Postby jim13 on Mon Jul 26, 2010 10:29 pm
BestNThDez wrote:Johnny, out of curiosity, is it really necessary to plug the ends of the pipe before freezing? It doesn't seem to me that it'd make a difference, since it's the ice that forms that will push the dent out. Unless of course it's to keep the water from spilling out before freezing. I've never tried this technique, but heard it works well for larger dents and that sometimes several freezes are necessary.
I didn't plug the ends on the header I used. But, I have the freezer space to position the dent at the most downward position, where smaller freezers it may not be as easy and may require a plug to keep the water in. It's just a thought, I'm not sure really as I haven't been in that position yet.
jim13
Lurker
Lurker
Postby Tristan899 on Wed Jul 28, 2010 6:28 pm
Thank you guys for all your advice.
Tristan899
Lurker
Lurker
Postby 67baja on Wed Aug 25, 2010 10:10 am
I just stumbled across this thread on TT. It has a before and after pic, and they did not plug the ends of the pipe.
http://www.thumpertalk.com/forum/showth ... p?t=915828
West Coast Residential Maintenance - specializing in rental property maintenance
User avatar
67baja
Knee Dragger
Knee Dragger
Motorcycle: wr450,Z750s,rd400
Return to Dirt Forum
Who is online
Users browsing this forum: SERRANO and 2 guests
